C6te 6090g
how do these heads compare to C8's C4's and C1's?
The C6TE is not a bad head, Ported they can run + or - 296/200 at .700" lift at valve.... with CJ size valve's..
RJ |
That head stock should flow the same as the C1, and the C4, and will out flow the C8 but roughly 40cfm on intake, and 10CFM on exhaust. It has a large cumbustion chamber, like the C1, and C4 (at 71-74cc), the C8 has the small cumbustion chamber (at 67-70cc) Those C6TE-G's should be able to flow over 300/210 at least, w/ stock valves.....and a good port job
