A couple questions I feel silly about asking
Where did the sticky posts go that had the common mods and acronyms?
Also, what does EBPV stand for? |
I don't know where the sticky mod went. I was looking for it the other day. EBPV (Exhaust Back Pressure Valve)
Cuda_Jim has some of that information under his posts.
sticky thread for common mods down below in my sig
EBPV= exhaust back presure valve |
From what I understand, the admins are modifying the sticky and have taken it down while they do so.
I uderstand there is a ebpv mod that costs about $20 and comes in handy if you're pulling a 13k load. Where might I find info on that?
i was serching through my favorites and found this that was in the sticky's..hope it helps you...
https://www.ford-trucks.com/forums/s...4&postcount=19 |
Here is Kwikkordead's writeup on how he did his:
https://www.ford-trucks.com/forums/2...brake-mod.html |
Thanks Strokin. Read the write up...Kwik is stick, mine is auto trans and requires provision for the convertor lockup. Is there any info available for auto trans in this regard that you know of?
Thanks again. |
Thanks Ron for the sticky's but nothing in there for the ebpv mod that I can find..
Originally Posted by Kwikkordead
That is correct. It's out of my hands.
-David |
how did you find this forum? just curious |
Originally Posted by Tenn01PSD350
IIRC Cookie said that the stickies will not be returning. At least not as we knew them.
Some of the previously stuck stuff may be returned as admin finishes it and passes it back to us, but you guys that have tracked down and marked the old links already have the best solution in place. :) |
