radio quit
my radio quit this moring. The clock will come on when i turn the inside lights on, wont take a cd, dose anyone know where to look for a fuse? it was down to 24 this moring would that have anything to do with it?. worked when the truck was parked last night.
this is not good I cant :-headbang while driving now thanks Keith |
One of the little fuses down under the dash is radio power......can't remember which one, but I think it's marked as radio.
Our trucks have a radio???:-huh OK, I know they do but I have not really used mine since the exhaust install. Radio fuse should be listed in the owners manual. I believe it's also labelled on the decal on the removable access panel. Not sure why the clock works and radio doesn't, that doesn't sound right.
started working after the truck warmed up? started the truck let it warm up to operating temp and the radio was working when i got in. any idea why it would not play untill it warmed up??
going to order the exhaust next week. not sure when i will have time to put it in. working on my roof so the snow dose not fill up the deck and drop in front of the door. depending on the storm could take meup to four hour to clean it all up. then to hawaii :-wink home in time for the snow to start falling. |
Idaho City dont get any snow
going to order the exhaust next week. not sure when i will have time to put it in. working on my roof so the snow dose not fill up the deck and drop in front of the door. depending on the storm could take meup to four hour to clean it all up. then to hawaii :-wink home in time for the snow to start falling. PS> I live in Mt Home |
I've discovered that in cold weather my radio screwts up only when the heat/ac switch is in the on position. Next time you do a cold start first time for the day turn off the heat switch first.
Markadeck
I will give that a try Tom I PM you back i am leaning towards doing it :-X22 Keith |
