65 f100 front end swap
I am looking at swapping the front end on my 65' f100 which has a 300-i6 and 4 spd manual with the front end out of a 94 f150 w/ 351 f.i. and auto trans. Has anyone done this before? Will the suspension/steering components fit-up without cutting/welding? Any help would be greatly appreciated.
The engine/ trans combination sounds great, but you might be better off finding a 73-79 parts truck to get the discs from as they are a direct bolt in. The newer parts might not be worth the trouble. The steering box is mounted ahead of the crossmember from 80-up so unless you want to get into some heavy welding and fabricating, it's probably a good idea to stay with older parts.
nj WILL NOT CHANGE. 65-79 year models are the same and will interchange. All like parts will change out, and bolt in, but not past that.
John 66 F100s In the still cool hours of the night, you can hear chevys rusting away. |
