Looking for gauges installed in dash pictures
A short while ago (1 month?) I saw some pictures of a rig that there was a water gauge and a voltage gauge I think installed in the spaces right below the instrument gauges and on each side of the steering column. I've searched through hundreds of gallery pictures until my eyes are popping out of my head. Need to ask the owner a couple questions. Thanks for any help.....
Marty |
Although these are nice, not the ones. The ones I'm talking about is below the two outboard gauges in the above picture and inseted into the dash on each side of the steering column. Nice and clean setup. Thanks for the try though.....
Marty |
Check my gallery,, I had my EGT and Boost Gauge there in the beginning,,actually they are still there to fill the holes, just disconnected them when i got the X monitor.
https://www.ford-trucks.com/user_gal.../64460.520.390 |
How do you like the X monitor Mr. Bass?? Is it worth it or should I stick with conventional gauges?
Yep your the one :) Had a couple of questions and might as well ask them here in case it can benefit someone else. Are those standard size 2 1/16" gauges? How much room did you have behind the dash and was there anything in the way to be concerned about? One more thing...thanks for the response. I want to put voltage and water temp gauges there and like how clean looking your install was.
Marty |
