1984 f150,300,4.9LT,inline 6cyl.
hi,will here from canada,I have a 1984 f150,I'm having starting problems,getting gas but not any spark,I've replaced ignition module,ignition coil,and checked wiring harness,but still not any spark,can anyone help.
Can't help much except to suggest you start at the plugs and work backwards till you find electricity and then repair or replace the failed connection or component.
TFI modules are always suspect. Make sure it's on right, plugged in right, and did you clean it and put the new goo on it when you screwed it on the dizzy? Good luck. I'd hop up to help you out but I could buy you a replacement truck for the airfare. And if I could do that, I buy me a newer truck.... |
Have you checked the cap and rotor?
