390 valve springs
Ive spotted a cam Id like for my 390. Its a Crane energizer 266 with .513" lift. Does any one know if the stock valve springs can handle that much lift? Thanks
FTE has a FE engine forum for 390 engine questions.
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun! :)
JMO!!! |
I agree with bear. The stock springs will work up to the rpm limit of them. .513" lift is beyond stock and most likely the engine will have the capability to go to higher rpm's than the stock springs will go...the best option is to let crane tell you what springs to use.
Good Luck! Tracy |
If your stock springs and Valvetrain components are in real good shape? and not worn out? you shouldnt have any problem running a cam up to .550" lift.. (IF) all the parts are in good order.. JMO....
Russ AKA-RJ |
