Free Tuner!!!!
I need someone to swing by the office and pick up a Sniper Tuner, all we would ask is you bring me a 6 pack of beer, nah just joking, (Heinken cough)
Seriously though the only request we would have is that you do an installation article on the item and a good write up with your feedback and the tuner is all yours. Here is some more info on the Sniper <!--StartFragment -->
-Compression ratio -Supercharger (Roots & Centrifugal -Low / High fan settings -Turbocharger -Engine idle speed -Nitrous (wet & dry) -Passive Anti Theft -Injector size -Fuel Octane rating -Returnless fuel pressure setting -Headers / exhaust -Mass Air brand / calibration -H / x pipe -Intercooler type -Rear oxygen sensor delete -Fuel pump type -Trans shift points -Unlimited number of files can be created -Trans shift firmness -Engine rev limiter -Engine speed limiter -Tire height / speedo correction -Gear ratio / speedo correction -Air Fuel Ratio adjustments (richen/lean) -Spark advance (+/-) DIESEL Special Forces offers a wide range of adjustability: -3 levels of power (50, 75, & 100) -speed limiter -adjustment for NOS & Propane -trans firmness** - adjustment for smoke control limiter -trans shift points** -adjustment for aftermarket injectors (single shot & split shot) -converter lockup** -adjustment to Injection timing -adjustment for throttle response control -Programming time 30 seconds*** ** currently available for 7.3 liter only. Call me with any questions please refer to the Sniper when you call. 678-218-4337x105 Jay |
I can't believe no one has taken you up on the offer, or have they? I am in SE GA, probably not where I can run by and pick it up.
Thanks for the interest but I sent it out earlier in the week, I will keep you in mind in the future, we have lots of goodies we are going to start giving away, keep and eye out on the boards....
JAY |
