Bio-D and SVO in same tank?
Can I run bio-d and svo in the same tank. I've read some posts that say they don't mix well, but will this be a problem? I'll be running bio-d in cold weather and the bio-d would benefit from warming anyway.Mike
Not a good idea they dont mix at all. You dont have to warm BD to keep it from crystalizing just mix it with some good ole #2
What he said :-D
Thanks for the replies. What exactly is the problem with bio and svo not mixing, as long as I'm using the svo heaters? Do they react to form another compound?
I'd rather not have to use any #2 if I don't have to. I have two tanks on my 87 6.9 idi, so one would always have bio or #2, but on a long trip I'd like to use svo when available. Mike |
The specific gravities of the two liquids are to far apart.
WVO is a much larger heavier molecule than BD (that's why the specific gravities are different) |
SVO not WVO?
I believe he wrote Bio-D and SVO. SVO is different than WVO. I understand SVO is refined vegetable oil like you cook with. Waste vegetable oil is the stuff that restaurants use in their deep fryers. I also believe that this stuff is often a liquid shortening meaning it is partially hydrogenated. If he meant WVO great. If he actually meant SVO, then I would like to know if those two can be mixed.
It is still no. Just because it was used in a fryer doesn"t change the specific gravity and they will not stay mixed.
I get that they don't mix, but what difference does it make as long as I have the heating system to liquify the svo/wvo? Won't they still ignite in the combustion chamber?
It separates in the tank with the different gravities. Until well mixed by truck movement.
If you run WVO or SVO it is imperative that you start up and shut down on straight diesel. The only way to assure that will happen is two seperate tanks and essentially seperate fuel systems; diesel to start and shut down VO to run. Failure to do this can produce early engine failure. If you just mix the two in a single tank it will seperate into two layers. Your truck will be running on which ever layer is at the tank pickup at any particular moment. If it happens to be the VO layer when you shut down there is a very good chance you will have a lot of trouble getting it started again.
You need to ask a VO expert about using VO the sponser of this forum is Lesk WVO conversions. they have a link at the top of this thread. You can also get hold of them by starting a new thread titled "Questions for Lesk WVO" |
Thanks for all the imput and patience with my question, but I guess I'm not presenting this clearly.
If I have two tanks, one with bio or #2 and one with svo and appropriate pre-heater lines, why can't I run bio/#2/svo through the heated line,as long as I do the start-up/ shutdown on Bio or #2 from the first tank? Is there a problem running bio or #2 through the heated svo line? The situation I imagine is finding a cheap(haha) price for#2 while on the road and wanting to fill up the second tank that may have some residual svo in it. |
Hmmm little different scenario there. I have been told that once you use a tank for VO you should never put Diesel in it again. I dont know why.
Once again I suggest you contact Lesk WVO to get an answer to that question. My thoughts are pick a system and go with it. Any time I have watched someone try to embrace multiple paths to the same objective it ended up costing them in the long term. I guess my question is if you are going to run Bio Diesel why bother with the VO at all it will essentially double your initial setup cost, may lead to problems, and is an unnecessary complication. Just convert all VO into BD and don't worry about it if you find some one giving away #2 just smile and fill up your tank. Or mod your truck to run VO and dont worry about that occasional #2 bargain cause your never gonna find #2 as cheap as WVO. |
