196? F100 what year do i have?
hello, sorry to have to ask the same old ? again.but i have a old truck with no title but want to know what year i have so i can order parts.it is a F100 with a vin # of F10YLC59872 body style K 81 trans B axle A8 H.P 172 . i has what i think is a 360 for a motor with a manual trans.(three on the tree with a over drive) how do i work the over drive(the pull choke type lever) and electric on the trans?is these the right combo for this vin.also the hub caps look like mercury dime heads is these right? thanks for any and all help. ps i dont think it is a 67 so i dont think the info is listed here yet.:-huh
Your truck is a 68 as the C59XXX serial would indicate. The engine code Y is a 360. I'll have to dig up the other info.
thanks for the help where can i find more info from the vin #?:-X04
is there a way to tell if i have a lock up rear end,or a limited slip, or just a opened rear end.possibly by vin , axle code(A8) spinning tire.i just dont want too crack open the cover yet to check but it might need the additive to make it work?any help out there?
You can decode the VIN here...
http://www.67fordtruck.com/VIN-Plate.html GolferSA :-X22 67 Ford F100 Custom Cab 352V8 C6 Auto Factory Air https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5688&.jpg golfersa@netscape.net Check out my gallery! |
