throttle body diameter
I am looking for the dimesion for the throttle body diameter on my 2001 Excursion. would getting this:
throttle body would increase air flow into the engine? I do not know the stock dimesion after searching the past posts! The site explains it will fit F- series and excursions! |
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords. Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS! …..See you on the boards.:-X22 |
I believe it will fit the v10, the 5.4 has a single bore. In my experience, you should also do injectors, roughly 10% bigger than stock to compensate for the airflow.
I don't know what other mods you have tried, but a cold air kit, a program and exhaust are usually done before throttle bodies. |
