Temp Senders, Identification?
Can anyone help me figure out how to differentiate the 6V sender from the 12V sender that threads into a bung @ the rear of the drivers head water passage?
I believe the threads may be different? Thx. David |
temp senders
There is a good picture of temp senders and the Bung they go into on a thunderbird site. www.parts123.com
look under 55-57 thunderbirds search "temp" I beleave the 6volt sender is longer and has two wire tabs. looks like the ones i've pulled off engines. check out picture. it also has part numbers |
Thx. a bunch for your leads! That did it, I was able to Pos. I.D. the sensor I wanted to bid on on Ebay. David
