sig picture
i made a picture of 2 of my trucks with some text in paint, and i downsized it with pixresizer, but nomatter how much i downsize it, fte blows it back up when i try to put it in my sig, and then since i donwsized it, and fte blows it up, it distorts it, what the hecks up?
Looks like you figured it out.
It displays at whatever size it was saved at. Right click and check "Properties". |
no, this is just a resized one of just my truck, but ive got another one that is of both of them, thats cropped and whatnot. nomatter what size i resize it to it shows up huge.
Sounds like your resizing program may be bogus. I use a couple of programs and it works for me (photoshop and irfanview). There are a number of programs listed in this forum. Some work better than others.
If the pic is in your gallery, just use the thumbnail image in the forum codes :)
i tried, and it shows up about .5 inches wide.
Try it without all the other stuff in your sig :)
this is what it is, this is the downsized pic, so its distorted. https://www.ford-trucks.com/user_gal...id=104578&.jpg
That pictures is 520 x 266 pixels. When you reduce in size you loose details. You normally need to reduce the picture to less than 80 x 80 pixels. You will not be able to see ANY detail at that size. To preserve the aspect ratio I reduced it to 100 x 50 pixels at 1.76Kb and it is way too small to see.
im just going for what ivan has in his, how he has details right on the picture of his truck, i just cant figure it out.
