351w to 460 big block
how hard is it to change over a 351w to a 460?can i use any of the parts off the 351w on the 460 or no?will it bolt right in?any info will help thanks.the truck is a 95 f 250 4x4 .
nothing will swap over. you need a new tranny, engine and all the parts.
ok i was told the tranny i have now e 40d would bolt right up to it but i guess the guy was wrong.a local junk yard has a nice 460 here not sure how much they want for it though im guessing it will be at least 1200 or so?
no the bell housing patterns are different.
1200.00 for a used 460??????? thats a rip you can get a new one for that price www.rebuilt-auto-engines.com
wow really thanks for the info man.its a 460 out of a 97 f 350 the guy told me with 80,000 miles. ill check your link out thanks for the info.
I'm swapping a 302-460
yeah nothing will swap over. see what tranny is on it and use that. I got a 77 lincoln with a 460/c6/9" for 800 dollars ran and drove smooth. I'me trying to get the 460 into my 85 f-150. see if you can just buy the whole truck! you'll have to go to ford and buy the motormounts that go on your frame. they just discontinued the ones I needed but they found some on the shelf somewhere in texas and sent them. If you get the whole truck you should everything you need but the part of your frame to accept the mounts on the 460.
