Hey guys
Hey guys, whats goning on? I just registered on the site and I am a proud owner of a 93 black lightning. Just thought i would introduce myself to the community. I'm also interested in any ideas on how to improve my trucks horsepower. Any thoughts would be greatly appreciated.
Hi and welcome to FTE!
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site. https://www.ford-trucks.com/forums/showthread.php?t=300691 We are happy you have chosen the best source for Fords! Enjoy FTE and The State Chapters are located at the bottom of the main forum page. JOIN CLUB FTE -SUPPORT THE FORUMS! See you on the boards.:-X22 …. |
Congrats!
Some good bolt-ons for a GEN 1 L are headers, exhaust, pulleys, CIA and advance the timing 2-3 degrees. |
What it CIA
I am prety new at working under the hood. I know the basics of the engine but thats as far as my knowledge goes. What is CIA and how would I advance my timing? Would there be a realiabilty issue if I did?
CIA=cold air induction. Essentially, you want to open up the inlet tract and Replacing the stock air box and filter, with an open element (cone type) filter is essentially the same.
Advancing the timing is easy: With the motor off, find the spout connector and remove the jumper. You can find the connector just under the cruise control servo on the passenger side fenderwall. Once you remove the jumper, you just set the timing like normal; loosent the distributor bolt, attach the timing light clamp to the #1 plug wire and start the truck. If the timing hasn't been messed with, then it should be set to 10 degrees BTDC on the harmonic balancer. Make sure it's warm when you do this. If you need more/detailed info, then let me know. |
Matt, isn't the spout on the drivers side?
And I just so happen to be selling my CAI for $175 shipped.
https://www.ford-trucks.com/classifi...ct=7677&cat=10 |
