fuel capacity for 90 f250 w/duel tanks
wondering if anyone knew? searched and couldnt find anything. anyone know a link for the specs on a 90 f250 4x4,i cant find any info on this truck. thanks
F250 Reg Cab 2- and 4-wd: 22.0 gal front, 18.2 gal rear
F250 Super Cab 2- and 4-wd: 19.0 gal front, 18.2 gal rear From the '90 F-series owner's manual. Jason |
those look like longbed figures Jroehl
I think the front tank shortbed SC is 16 gal and the reg cab is 19. The rear tank is always 18.2 gal. Thats for the F150 which I don't think changed for the F250, did it? |
i have a long bed ext. cab
1990 F250s didn't come with a shortbed. Reg cab long bed (133" wheelbase) or Supercab longbed (155" wheelbase) were the only options. The 16.5 gallon tank was only on the shortbed F150s in the front. F350 chassis-cabs and F-Superduties came with 19 gallon tanks front and back unless they had a diesel, then they had a 20 gallon front tank (except the DRW chassis cab F350 diesel, which had 20s front and back).
I've got the 1990 manual sitting right here...any more questions? Jason |
thanks jason, would you happen to know how i tell if i have the weaker mazda 5 spd tranny in my truck or not ??
What's the tranny code on your door sticker?
Or, what engine is in the truck, and what is the GVWR? Jason P.S. I just saw in another thread that you have the 351W--that means you definitely don't have the Mazda, you have the ZF. The Mazda doesn't fit the 351W bellhousing pattern (at least not from the factory). |
i'm sure Jason's correct, but just to be sure, crawl under and look for the ID tag on the tranny. if it's a ZF, it should have an ID plae on the driver side that says ZF somewhere on it.
Mike |
thanks,ill crawl under there and check it out.
1234567890
I've got a 96 F-150 Reg. Cab Long box 4X4 and I candefinetly say that my front tank is bigger than the back
