Ford Truck Enthusiasts Forums
-   1983 - 2012 Ranger & B-Series (https://www.ford-trucks.com/forums/forum35/)
-   -   Airbag code 12?? (https://www.ford-trucks.com/forums/433694-airbag-code-12-a.html)
Fullcontact 11-26-2005 01:17 PM
Airbag code 12??
My Airbag light is flashing code 12 at me. Does anyone know what this code means?
IB Tim 11-26-2005 04:07 PM
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.:-X22
Dave257 11-26-2005 05:07 PM
Maybe a 21 ???
I don't have a 12 listed, could it be a 21?
Here are the codes for Air Bag faults. When frist started the dash light will blink the two digit code before it comes on permently.
Continuous (blinks no code)
RCM Disconnected or Inoperative, Loss of Battery Feed, or Loss of
Signal Ground
15
Incorrect Vehicle ID
15
Driver Air Bag Circuit Shorted To
Ground
15
Battery Or Ignition
16
Passenger Air Bag Circuit Shorted
To Ground
16
To Battery Or Ignition
17
Air Bag Tone Warning Indicator
Circuit Shorted to Ground or Open
17
Driver Pretensioner Circuit
Shorted To Battery Or Ignition
17
Shorted To Ground
18
Passenger Pretensioner Circuit
18
Shorted To Ground
18
Circuit Short to Battery or
Ignition
19
RCM Crash Data Memory Full
21
RCM Bracket Ground Resistance
High
24
RCM Is Faulted
25
Passenger Air Bag Deactivation
(PAD) Switch Fault
27
(PAD) Warning Lamp Inoperative
27
(PAD) Warning Lamp Shorted to
Battery
32
Driver Air Bag Circuit Resistance
High
33
Resistance High
34
Low
35
Resistance Low
46
Resistance High
46
Resistance Low
47
Resistance High
47
Resistance Low
Dave
woolie74 03-08-2006 06:58 PM
The infamous code 12
Code 12 seems to be a couple of things
loss of voltage at pin 14
low/loss of battery voltage
these are what I found.
