what oil to use in FE 360
I was browsing through the threads a few months ago and i remember something about using diesel oil in the FE engines? I am posting this topic because i can't find where the thread is. Any suggestions as to what weight to use ? 15w40?
Any help would be great. even if you can find that old thread so i don't eat up space on the forum! 1975 ford f350 dually "The 75" |
15X40 is good , you might check the FE forum as 360s are FE engines , and I think using up space helping each other out is a good thing and one of the reasons this site is here,bob
I would stay away from the Diesel oil... Run what oil is appropriate for your climate, nothing special needed. I run 10-30 in my older vehicles (pre-90) and the recommended mfg weight in the newer ones (generally 5-30).
--Mike |
Yep, 10-30 is good 15-40 is a little thick in the cold.
I run Shell-Rotella 15w40 in my 300L6. The diesel oil has more anti-wear additives in it.
I run Royal purple synthetic 10w30 usually, just dont break a engine in on synthetic ..
I run 10w40 summer and 10w30 winter
I run 5w30 in winter and 10w40 in summer.
I run straight 30 Valvoline in my 390 in the summer and 10w30 in winter.
Actually, diesel-grade oil would be a great choice for you, with a much better additive package, especially for an older vehicle. It is available in 10W-30. I use Mystic JT-8 Super Heavy Duty, but there are others that are good as well - Rotella T, Delo 400 to name a couple. |
what oil to use in FE360
I vote for the 15-40W family of diesel oils. Delo 400 or Rotella are excellent choices. You might pay a penalty in milage(theoretically) with the thicker base weight 15, but the diesel family offers a superior additive package. :-X22
I use the Mystik 10w30 mentioned above in my high performance 390. It does work good. Had the heads and intake off a couple months ago, and got to look at the cam. It broke in correctly.
I used the same oil in the old 360 I took out. Everything was nice and clean when I took it apart. |
what should i use in my fe 360 with a slight knock? Its a tired engine
Originally Posted by OLDBLUEF250
(Post 16049012)
