New Methaloxide Mixer
:-wink Just built my new methaloxide mixer! Now I can mix 25 gal at a time SAFELY. I used a 30 gal HDPE barrel mounted "upside-down" on a raised metal stand. One of the bungs has a short pipe, elbo, and quarter turn valve mounted in it to release the mix directly into my mixing barrels. The top has a 1/4 hp SEALED elect motor with a extended shaft and paint mixing head mounted at the rear. In front of the motor is a hinged lid for pouring in the "micro-bead" lye. A 5 gal HDPE bucket is connected by PVC pipe to the top of the barrel. Inside the bucket is a fine mesh screen on the bottom where the pipe from the mixing barrel comes in. Then I filled the bucket with activated charcoal and put another layer of screen. A 120v blower is hooked to a pipe that fit's in the top of the bucket. This blower pulls air in the "hatch", through the mixing barrel, into the charcoal cannister and exit's OUTSIDE. NO more dangerious fumes!! NO more explosion hazard!! The barrel is marked in 5 gal incriments so I can watch the level while drawing off the "mix" into my mixing barrels. It works GREAT!! Will post pictures when I get my new camera[ last one fell out of the pickup!]. FABMANDELUX
sweet. PICS PICS PICS. :-X22
Diesel Rod |
Nice work. 2nd vote for photos!
I am researching building a unit so I am very interested! |
That's awesome!
I am interested in what was involved in building and running your still to reclaim part of your methanol also. I have the money to build the processor now, I just have to gather the parts. If this works out well, I plan on running all diesel vehicles and even converting my house to run on a diesel generator! Less money in the man's pocket means more money in mine! Keep up the good work Fab! ;D |
Methanol Still
Originally Posted by digracer
That's awesome!
That's great! I want to build a processor like you have, but I am still not 100% sure of what I need and how to set it up properly. I am more of a hands on learner. I like to see how the process actually works. I will study the pics you already have of your setup and see if I can visualize the running process.
As far as the methanol still, it sounds pretty staight forward. Is there a reason for using stainless, or can a person use a modified water heater? Also, if left running longer, would more methanol be collected? Also, I notice you like to use a 60 degree angle. I think you also mounted part of your processor at that angle. Is it just to increase surface area in this case, or is there another reason? Last question, (for now). I am still trying to figure out what to do with all the glycerin I will produce. I can only use so much soap and degreaser. I was thinking of building a type of stove to burn it. I don't need it for heat, but I don't want to just dump it on the ground either. Will the glycerin even burn? I think I'll start a thread asking what others do with their byproduct. Thanks again for all the info Fabman! |
throw glycerine in the garbage can
the environmental health dept. here in utah told me to put it in the garbage as long as it was solid
Sure sounds like this is the way to go. That processor sounds like it will work very well.
