elwardo13 |
10-19-2005 08:51 AM |
Changed The Cps..did Not Solve The Problem
I changed the cps as a solution for psd starting and quiting after about 2-3 min. With the old cps I could start about every hour. Now once a day. I get absolutly no error codes with the auto scanner from the parts store. I even tried disconecting different sensors trying to get a code but no luck. It acts like the fuel suppy just gets cut off after running a couple of min. With a hurricane on tis way I would really like some help getting this running. Could it be a fuel pump, the ICP, the IRP the HPOP level......? Houw do you check the HPOP level?
Help,
Tom
