Biodiesel ignition Q's
From what I understand when using Biodiesel in your engine you have to retard the timing 2-3 degrees. Why? Can you overcome this by using a hotter ignition system?
I have never heard that. so far no one has had any issue with out retarding the timeing that I know of.
maybe because the way bio is made, any residual methane jacks with the timing and retarding it will counter act it. just speculations.... Diesel Rod |
IP Timing
The only reason to retard IP timing is to lower NOX emissions. Biodiesel is an oxygenated fuel with a higher cetain rating than dinodiesel, It will generaly raise cyl temp by 50-100 deg , raising NOX emissions. By retarding 2-3 deg it will lower emissions. But it isn't required. FABMANDELUX. |
Here is a site on biodiesel, are truck are going to it. www.hugrsystems.com
Any clue on what percent by mass of oxygen? |
Originally Posted by PSD 60L Fx4
Really?!
Any clue on what percent by mass of oxygen? Depends on feedstock, approx 6 -10 percent. We had ours tested: 8.4 percent.FABMANDELUX. |
Fabmandelux is the man when it comes to this stuff. Guys read up at biodiesel dot org and ask this man here, youll get it right
No engine modifications are needed for the soy - biodiesel. go to www.biodiesel.org they have all the info you need.
I didn't really notice a power improvement but, my truck seems to consistently get 2 mpg better on B20 than straight dino. Which to me would indicate a small power gain which I would assume is from more BTU's per gallon.
More BTU's?
I didn't know that. I have been reading a lot of the post on alternative diesel it is very interesting.
Yes the biodiesel from crystalflash @ 5% soy is 51 min cetane. VS 40-42 cetane for #2. Just like adding racing fuel to your car.:-D
