dealer oil change and rotation fiasco
I went to the dealer in Wy. to get my oil changed while on a cross USA trip with my RV. Dealer put in 10w-30 oil when diesel supplement states that when temps are over 50 F, or towing a RV, the oil should be 15w-40. The temp at the time by the way was about 94 deg.'s. I had the oil changed immediately to the proper 15w-40 after I saw it on the invoice. While it was there I figured I would get the tires rotated and balanced since it had 6200 miles on the truck. Whoever did the rotate and balance scratched 3 of the 4 aluminum Lariat wheels. Needless to say I was sick and I must say that it has been several months since the event happened but Monday I am getting the new wheels put on. When you think the dealer is going to give you the best service for your vehicle, I'm a bit gun shy about going back to any dealer at the moment for service.
A lot off times these 6.0s will run much better on 10w-30 then 15w-40. I tried 15-40 once in my 7.3 PSD an the thing did not run right went back to 10-30. Quirky but true. The oil was the right specs to. Been 10-30 ever since. It must have been a shock to you to find out you had 10-30 instead off 15w-40. No excuse the dealer should have told you. These rims on these trucks are a bear to remove the aluminum sticks to that iron. I tried it myself an drove myself crazy.
When I remove my wheels to rotate them I brush a little Never Seize on the inside of the rim to keep them sticking to the steel hubs. Works well.
:-X06 |
At 6200 miles I do not know if it was your first oil change or not, but your truck came from the factory with 10W30 in it.
JFYI. RoyC |
That seems odd that it would have come with 10w-30 when the diesel supplement states that anything over 50 degrees F. should have 15w-40.
Is this a break in oil? I did change the oil myself with Ford motorcraft oil at 1260 miles only because it had been six months or better since I bought it. So to keep it under warranty rules I changed it. Then on our trip to the west coast I had it changed after 5000 miles under heavy towing through the mountains I felt this would be a good time. The dealer was a small dealer and who would have guessed that it would have created such a problem, with the oil and the scratched wheels. Which by the way were replaced yesterday at my local Ford dealer. So all is well again! :-X22 |
It's not a "break in oil." It's 10w30. That's what they put in the truck during the initial "break in" period.
That wasn't in Evanston, WY, was it?
is there a ford dealer in evanston? I didnt think there was.
dana_wildcat
Welling Ford in Evanston, WY. Its been there since Henry was a baby--and their service bay hasn't changed a bit since it was new. |
