What is the largest filter I can use?
In a FL1A application? I want to put a larger filter in my 92 XL all manual. Thanks.
The best bet is to run a FL299 which is 1.5 inches longer and the same in all other respects, but probably a thicker can since it is longer. But the FL299 is expensive at the dealer. I order the Purolator version (L40017) for $6 at Advance Auto and they have it the next day. This particular Purolator has the Motorcraft-style threaded end bypass valve too.
TallPaul is right! Here's a list of larger filters, including the FL-299. I've cut open "virgin" filters and measured the surface area of the filter element. TP did the same with the Purolator, which I don't have on my list... perhaps he'll post it, as well.
Here's the list: Code:
Pleat # Element Surface |
Thanks for the help.
at kragen you can get 2 purolater filters for 5.00 on sale. they had the l40017 in stock and sold me them both for 5.00.
Thanks for posting your list Big O Dave. I tried to link to the Oil Guy site and it would not work. Here is my Purolator L40017 data (used filter vs Big O Dave's were new) next to Dave's FL-299 data:
Code:
Filter Pleat #Pleats Element Element I use the L40017 on my motorhome and sometimes on my 300 I6. Not to leave the very good FL1A behind, I am running that on the Aerostar 3.0, which specs a FL400. |
*bump* ;) :-wink
Thanks guys for the help. I was considering the filter area, and possibly a little more cooling?
i my ford calls for motorcrat fl820s...i use a much larger size 5.6 in long compared to fl820s 4 incs...fleetguards lf3315 and baldwin b281...
