How do I remove the oil pan on my 2000 Ranger?
We have a 2000 XLT 4X4 with a 4.0L engine. We have taken out all the screws on the oil pan and lifted the engine, but still can not get the oil pan out. Can anyone please tell us how to get the oil pan the rest of the way out, so we can check the bearings?
HELP PLEASE!!!! |
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question. We are happy you have chosen the best source for Fords! Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS! …..See you on the boards.:-X22 |
Welcome to FTE!
As far as I know, the engine must be removed, or at least significantly raised with a crane or hoist, in order to remove the oil pan on a 4.0L 4x4. I've never heard of any short cuts to that, sorry. :( What are you gettting hung up on? |
Originally Posted by Rockledge
Welcome to FTE!
You'll need to raise the engine enough so that the pan will clear the bottom of the main caps and pump pickup. You might have to jack it up a good 6" to get enough clearance.
