Aftercooler
Does an 01 Lightning have an aftercooler under the supercharger? I have been told by some there is a cooler wedged between the charger and intake to assist in condensing the air. Is this true?
WP |
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question. We are happy you have chosen the best source for Fords! Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS! …..See you on the boards.:-X22 |
They call it an intercooler. It doesn't condense the air, either. It cools off the intake charge in order to run more advanced timing. Anybody try water/alcohol injection yet?
Thanks Steve. For clarification, is the intercooler after the supercharger, before the intake?
WP |
The I/C sits directly under the blower. Here is a link to one that didn't has an oil seperator installed. See all the oil that comes in through your PCV system!!!!http://www.nhtoc.com/forum/showthrea...ercooler+clean
