01 4.6 EB- Fog lights with headlights possible?
Does anyone know if it is possible to modify the wiring that will enable the opeation of the fog lights without having to turn on the headlights. I know this is superficial and not an actual "functions and operability" issue but I'm a curious sort and like to do the uncommon from time to time. This can be evidenced by some of the modifications I've made to it over the past year.
Thanks for any available assitance and help. '01 4.6 Eddie Bauer 2WD Pacesetter Headers Dynaflow Dual Exhaust Freeflow Cats Cold Air Induction Throttle Body Spacer Projector Headlight w/ Halo Altezza Taillights Kenwood DDX7015 DVD/CD/MP3/SIRIUS/NAV Bluetooth Cellular Handsfree 12" Amped Sub 13" Flip Down Monitor w/ IR Transmitter Full Woodgrain interior 22" ASA TR II's w/ 305/40 Toyo's |
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question. We are happy you have chosen the best source for Fords! Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS! …..See you on the boards.:-X22 |
I recall that its possible to recontour a portion of the inside of the headlight knob to allow the switch to be pulled out to the fog position, without the headlights being on. Never did it, but I know it's possible and no wiring mods are required.
Thanks for the help
Thanks Paul C. I'll give it a try and see what happens.
Try reading this link, should be very similar for a Expy.
https://www.ford-trucks.com/forums/a...%20Light%20MOd From above link; "Extending Fog/Driving Lamp Functionality in the 2000 SVT F-150 Lightning... This document is the culmination of data and experience gained in altering the stock functionality of the 2000 Lightning's Fog or Driving Lights. These are the round lights housed in the front lower fairing, and are referred to in this document as Foglights. This document is written based on my 2000 model year only, but the information presented here may be useful for other model years. In the stock mode of operation, you are only able to activate the foglights when the headlight switch is in the full 'on' (or headlamp position), ainly because it is the only position where you can physicaly pull out the switch to activate the foglamps. Through testing and guessing, I have altered my truck's headlight switch mechanism and wiring in such a way that I am able to: 1. pull out the headlight switch in the autolamp, the parking lamp, and the headlamp positions. 2. activate the foglights while the headlight switch is in the autolamp, parking lamp and headlamp positions. How? There are 2 parts I recommend in this procedure - the physical modification, and the electrical modification. Preliminary Preparations 1. Gather your tools. I used a small screwdriver, small hobby file, medium pair of pliers, 3M splice connector, electrical tape, and an air compressor (canned air will suffice). 2. Take a deep breath. If you are like me, I'm very hesitant to hurt my truck, so any modification is a big one. 3. Remove the headlight switch console. This console has three metal clips holding it in the dash- one on the bottom-middle where the 'notch' is, one on the left-middle, and one on the top-right. I simply used a small screwdriver to coax these clips into releasing the console from the dash. There are 2 sets of wires plugged into the back of this console. Results at this point: You should be ready to start working. Part 1 - Physical Modification: The Headlight Switch Mechanism 1. Disconnect the wires. The connectors to the back of the console have a 'lock' or 'latch' that you must press while wiggling/pulling the connector. I also don't recommend pulling on the wires - there is always the possibility of damaging a wire or pulling it from the connector. 2. Find the collar. If you look into the console from the bottom, you should be able to see the mechanical headlamp switch mechanism. There's a black plastic column that's attached to the headlamp switch that should rotate as you move the switch to its different positions (autolamp, off, park, on). Also attached to that column, inside the console, there's a black plastic 'arm' - this, along with the 'ramped' white plastic collar around the switch, is what prevents the headlamp knob from being pulled out in any position except the 'on' headlamp position. The easiest way to find the 'ramped' white plastic collar I am talking about is to turn the switch to the full on headlamp and foglamp position (turn switch full clockwise and pull it out). Now look for the black plastic arm. Now watch that arm as you slowly turn the switch counter-clockwise back to the park position. You should see the arm ride on a white plastic collar surrounding the whole headlamp switch mechanism. There is a 'ramp' in this collar that forces the switch to pop back inward when you turn from the 'on' position to the 'park' position. Good luck, this can be a little confusing. 3. Persuade the collar. Using a small file, I filed down the white plastic collar at the positions I wanted to be able to pull out the headlamp switch to activate the foglamps. I filed down the ramp at the 'park' position, but duplicated the slope on the other side of that position. So now the switch stays pulled-out in the 'on' and 'park' position, but still pops back in when I turn to 'off'. For the autolamp position, I filed a notch and ramp towards the off position. Again, the switch stays pulled-out in the 'auto' position, but still pops back in when I turn to 'off'. Make sure to clean/blow out the plastic filings from the casing. IMPORTANT: I do NOT recommend simply cutting the 'arm' from the switch column. This negates the collar's secondary function of being able to provide 'stops' for the switch mechanism. One bit of feedback I have gotten from someone who just cut the arm is: "Without the sweeper arm, the whole switch is kind of wonky. It pulls out too far and will also rotate past the autolamp position. Just don't like the feel." NOTE: Since this is a single-piece part, I chose NOT to take off the faceplate to make any alterations. I'm sure one can take the thing apart and superglue/epoxy it back together, but I'd rather not break plastic pieces apart if I don't absolutely have to. Results at this point: Your foglamps should now activate with your headlamps in autolamp mode. Reassemble everything, turn the headlamp switch to autolamp, pull out on the headlamp switch, and turn the ignition to 'on'. You can now fool the autolamp sensor (underneath the plastic 'grille' in the middle of the dashboard) to activate by covering it and deactivate it by shining a flashlight into it. NOTE: Canadian owners' trucks will work diffenently at this point. Instead of the foglight only turning on with the autolamps when the switch is in the appropriate position, the foglamps will light whenever the ignition is on. This is due to the added DRL (Daytime Running Lights) feature, which is apparently mandatory in Canada. This is probably fixable, but requires the electrical splice described below, AND cutting the #2 wire away from the switch connector. Read on... Part 2 - Electrical Modification: The Headlight Switch Wiring This is the easiest part. If you look at the wire connector that plugs into the back of the headlamp switch, there should be 9 wires of varying colors. Although the connector has space for 12 wires, only 9 of them are used. Also, on the wire side of the connector (as opposed to the switch side of the connector, which is the side you would insert into the switch), the wire positions are numbered. Okay, find the #2 wire (white/black) and the #12 wire (brown) that is attached to the connector and splice them together. That's it! No cutting needed! Don't forget to electrical tape/insulate your splice well. NOTE: For Canadian owners, after performing the electrical splice described above, you shoul cut the #2 wire away from the switch connector to achieve the results below. Also keep in mind that this addition step is my best guess at a solution, but shoul be considered untested. If you try this on a Canadian 2000 Lightning, please let me know your results. Results at this point: In addition to working with the autolamps, you should now be able to activate your foglamps with just your parking lights. Make sure to test everything BEFORE popping the switch console back into the dash... much easier this way in case somethig is/goes wrong. Well, that's it for duplicating my truck's added foglamp features. There are, however, other possible variations to this procedure. For example: to convert your foglamps to psuedo-DRL's you can splice the #5 wire to the #7 wire to have the fogs turn on whenever you rotate the headlamp switch to the auto position (filing the switch isn't necessary for this one). Or to make the fogs always turn on with the parking lamps, you can splice the #5 wire to the #12 wire (no filing for this one either). If you want to make your own varient, I would study the data I gathered to see how you might go about getting the exact behavior you want." |
jmacd27- Thanks! You guys on this forum are the absolute best.
I'll eventually make mine able to be on with the high beams.... it has to be the stupidest law on the books that you can only have fogs on with your low beams. Can anyone rationalize it to me?
