1976 Ford F150 Ranger Carb
I own a 1976 F 150 Ranger 2wd Pickup. I replaced the motor with a 390 . I need to find a good after market 2 barrel carb. I have tried several 2150 motorcraft carbs but had no luck in the performance department.They suck!I just got done redoing the top end and is time to mount the carb.All the information I found on the 390 lists a 4 barrel. Can anyone suggest a good 2 barrel. Thank you .
Lionsfan 68Fordf100,1976 Ford 150 Ranger,2005 F150 4wd and 2-1993 Ford Thunderbirds |
Holley makes some good bolt-on 500 cfm 2bbls.
Thank You
Thank You ,Any perticular model you perfer over another?
they only make one style of them. summit sells them for about 225.00
I believe that they have one that is manual choke and possibly one that has an electric choke.
Thank you
Thank you for all your advice I have got the carb from auto zone for $209.00. Thanks
Happy motoring :)
