97 5spd std transfer case
Does the trans and transfer case share the same lub on my 97 f150 4x4? Which plug is the fill plug for adding lub? as there are a few plugs from what I can see--thanks,jeff
yes i do believe they share the same lube, as far as the plugs i think they are labeled fill and drain
