Drop in engine speed!!!
While driving a constant speed, 40, 50, 70 etc., when I get out of it, the engine speed drops about 500 rpm's. When I put my foot back in it, theres like a dead space there where it 'catches up'. This doesn't seem normal but I've never driven another diesel. I have to ease my foot back in it to avoid a jerk. Anybody experience anything like this? Thanks.
Is anyone out there?
Rirwin,
If I get you right, you put your foot back into it and you get a lag then the truck punches itself up. Ive been told this is turbo lag, so I think everything is fine engine wise, your shift kit maybe some of the jerk you are getting. Up shift or down shift |
It sounds normal to me. When you lift the torque converter unlocks. This allows the engine speed to drop. When you get back into the pedal there is a delay for the torque converter to lock. This delay is in the computer programming. After about 2-3 seconds the torque converter will lock again and the engine speeds drops.
Mine does this as well, Casey is right on
yes, as said before completely normal. its a good time to hear the turbo spool up before you get pushed into the seat:-D
