Need rear end help on 61 Econoline
I am new to the forum but have LOVED my 61 Econoline p/u for several years. It has been a great, good-looking daily driver and I have even used it often to move furniture and stuff for myself and for friends. Unfortunately the rear end is now apparently shot. It leaks like crazy and shudders so bad upon stopping that I have had to quit driving the truck. A local mechanic who specializes in antiques and is usually pretty good says the rear end cannot be repaired and must be replaced. Is he right? If so, are direct replacements available? If not, what else might work? I have heard that a Ford 9" will work and wrote to Jimbare about it, but I know he's busy. I have also heard that a late-model Ranger rear end can be used. I need ideas. Can you all help me out?
clemwp, Welcome to FTE :-X25 The best truck show on the net.
Someone should be along shortly to help you. I suggest that you try the search feature on the subject, while you wait. John :-X06 |
Sounds like the axle seals are leaking causing the brake shoes to get soaked in oil causing the shudder.
Does the rear end whine or clunk? If not it may be able to be fixed by replacing axle seals and maybe new bearings. dan |
Does the rear end whine or clunk? If not it may be able to be fixed by replacing axle seals and maybe new bearings. dan If it is those, look for another econoline with a rearaxle in and see if you can change it. The other is look for a mid size Comet, Falcon, Fairlane from the early 60's, for the gears in them would be the size to fit your carrier. If you know someone else that does differentials, maybe see if he can have a boo at it and give his opinion. |
Yes, the 9 inch will fit. I had one in my 65 and 67 econoline van. The ford Ranger and Explorer will fit, the only thing is, spring perches need to be moved.
brian |
Thanks, guys. The rear end does whine, and the shudder happens equally whether or not I apply the brakes. There is sometimes a grinding sound at low speeds, too. It is leaking badly, so I know the seals are gone. I'm thinking of just switching out the rear end and then seeing what I can do with the old one, at my leisure. I sure would like to find one from an Econoline, but failing that I'll take 66GPW's suggestion of what kind of vehicles to look for. Can you all tell me whether the gear ratio is marked on 60's Ford rears?
Randy |
Yes, there should be a tag on one of the bolts on the rear end. If some
one hasn't taken it off. Where are you located? I might have one. Brian |
What you have described sound too much like bearing are gone. Not the gears. The leaks are they at the sides with brakes or front where the drive shaft goes.
If they are the front it will be the pinion bearing. The sides are axle seals and bearings. The axle ones are easy to fix. The pinion takes more work, a lot of times you have to remove the gears. Either way you have to fix it soon or your axles can get heated and blued from the heat. This weakens the axles temper and risk breaking in the future. These bearings and seals are still available. Look on the back of the diff for a tag and it should say what gear system ypou have. The other is in the front door (drivers) is an identification plate. It says axle. If it says 01 your axle is 3.50:1 If it says 02 then it is 4.00:1 Hope that helps a bit. |
61 Econoline Rear End
Thanks, guys. The leak is not at the sides but at the pinion pearing. It was full and not leaking when I bought it, but apparently the differential has been run dry in the past because the gears now have that terrible clunking and grinding. The pevious owner probably re-sealed an already damaged differential, it seems to me. Given that the axles might now be bad, as you have pointed out, I would feel much better replacing the rear end rather than repairing it. I am in Atlanta and would love to get a line on where I could get one.
