How would I check a fan clutch?
What is the easiest way to check a fan clutch? I can easily turn it by hand when the engine is off and hot. When running and I shut the engine down the fan stops without even making 1 complete revolution.
I am having some A/C issues and think I am not getting enough air flow thru my condenser. I am thinking the fan clutch could be bad. Thanks, enjoy the Holiday Frank D |
When it's cold it should spin freely with the engine off, and it should be stiff when the engine is hot. What year van? It may be losing freon...
I just replaced the evaporator, it was bad. No leaks at all now it took a 3.5lb weighed charge of R-12, I have a few lb left over from many years ago (father in law). A/C blows cold when at a fast idle, hot slow idle. If I run the garden hose over the condenser the A/C will blow cold at a slow idle. It doesn't overheat.
When the engine is hot the fan turns easily by hand. Honestly I didn't try turning it when its cold: YET, I will do that in the morning. 1988 e-150 4.9L. When I turn off the hot engine the fan stops spinning in less than 1/2 a revolution. Thanks Frank D |
make sure the condencer is clean.
what kind of pressures are you running? did you check for leaks with a micron gauge? |
Answers to ????/from Crash687. All help is appreciated
what kind of pressures are you running? did you check for leaks with a micron gauge? This thing is driving me nuts! System held vacuum for 4 hours, we charged it, tested for leaks with a sniffer, no leaks, also used soap etc. Its holding a charge for 3 weeks now. At 550-600 rpm idle 60lb back pressure, 125lb high. At fast idle 1500 rpm 44lb back 225 high. (If I run the garden hose over the condenser idle pressures are about the 44/225 reading). I watched 3 fan clutches on 3 vehicles yesterday and mine is working exactly the same. The Condenser looks clean, I did not clean it (I will try that). I am in the process of replacing the engine thermostat and going from a 195 to 180 degree (Figuring it would cool the engine compartment, radiator etc.) Next step: I am thinking of putting a push fan in front of the condenser, in addition to the stock clutch fan to aid in cooling the condenser. The vehicle doesn't overheat now. I also checked the little oil that was still in the bad evaporator, it was perfectly clean, and there are no compressor noises. I am looking forward to hearing from you, thanks for the reply! Thanks Frank D |
(If I run the garden hose over the condenser idle pressures are about the 44/225 reading). I watched 3 fan clutches on 3 vehicles yesterday and mine is working exactly the same. The Condenser looks clean, I did not clean it (I will try that). I am in the process of replacing the engine thermostat and going from a 195 to 180 degree (Figuring it would cool the engine compartment, radiator etc.) |
More info, thanks Crash!!
Crash687 Said:
did you replace the desiccant when you replace the evaporater. you may have to replace the metering device and change the oil also. I did not replace the desiccant, or metering device, (accumulator dryer etc.) I added 2 oz of fresh oil to the system when we had it pumped down. The system was open for about 2 days while waiting for the evaporator to come in, (had to be ordered). We did evacuate the system, once the repair was made, I guess moisture is a possibility. I had the van out today, was in the low 80's and it seemed to be working well, but only went for about a 20 minute ride. I would hate to drop a full charge of Freon :-huh Thanks Frank D |
