F350 Vs. Chevy 3500 Pulling Rating
I have an F350 pulling a 5th wheel. I am going to buy a bigger 5th wheel but can't understand why Ford rates towing capability of the F350 so low compared to the Chevy 3500. Ford=12,800 max, Chevy=17,000 max. That just eliminates the F350 as a candidate for towing the whole catagory of luxury 40 ft. 5th wheels. Comments????
(If you could, please make a second reply directly to me: lgallup@mn.rr.com ) Thanks. |
OldGeezer,
Welcome to FTE, the best Ford Truck site on the Web. Check out our Guidelines: https://www.ford-trucks.com/guidelines.html And the Read First: notices at the top of each forum. What year model F350 do you have? The 05 F350's are capable of up to 19000lbs with the Tow Boss package. See you around... BigF350 |
I guess he has an older <05 and is comparing a new (er) chevy yes ford DOES compete in every way shape and form. Get a crew cab Dually 6.0 4.30LS geared FX4 lariet 6spd and trust me it will have you saying chevy "What" I promise.
tow rating for the truck abouve is 18,500lbs , 1500 more than thechevy and a nicer built truck to boot with 13.5K of GVW vrs 12K gvw on the chevy with means that you can load up the front of the fiver more and put gear in the back seat for more comfy camping |
with the 6.0 and towboss package the maximum tow rating is 19,200lbs.
OK what is two hundered pounds among friends.....hehe
Now there's a potential snake-pit...trailering capacities. The problem is the GCWR doesn't change, although the options and weight of the truck do- so weights range. On a "Tow Boss" equipped truck, the range is 18100-19200, depending on equipment, for 5th wheel applications only (otherwise trailering weights stay the same). On the Chevy, the range is 16300-17000. Of note, the Tow Boss is a Torqueshift-only proposition only (someone mentioned a six-speed...not on a Tow Boss).
At the rate were going we are going to need CDL's to pull at a 1 ton truck's capacity.
I recall someone in the 6.0l or SD forum (can't recall which) got booked for not having a CDL on his F350 when pulling a 5ver.
As long as your 5vr weighs less than 20,000lbs both trucks will pull them just fine regaurdless of ratings, IMO.
Thanks you guys.
I have a 2001 F350 V10 dually pulling a 5th wheel which grosses out just short of 10,000. I'm looking at pulling around 15,500 pounds. Day before yesterday my RV dealer got out all his latest charts - I mean, these are the charts these guys sell from when matching RV's to their buyer's truck. According to his charts a 2005 or 2006 F350 diesel without 4x4 (gives the highest pulling power) is at 12,800 lbs. For a new Chevy 3500 Duramax I would be at 17,000. Since I already own a Ford, I'm obviously not looking for reasons to buy a Chevy ( Chevy's just can't hack the abuse compared to a Ford as any honest old farm boy will tell you.) Anyway, you guys are way ahead of me 'cause I don't know from "CDL" or "Tow Boss" but I'm willing to buy what I have to buy to stay with Ford. On the other hand, just what the begeezus does Chevy have that makes it such a puller right straight out of the box? Regards, |
Check this out.
http://www.fordvehicles.com/trucks/superduty/features/specs/#tow Scroll down to 5TH-WHEEL TOWING with Automatic transmission, look at the 4.3 axle ratio (only available with the TowBoss package) 26000lbs GCWR and up to 19200lbs 5th wheel towing capacity for a Reg Cab F350 4x2 Dually. I think your dealer may not be aware of all the options available on the SuperDuty. |
BigF350
Man! Are you ever correct. It's all there - Everything I need. And to think that I messed around on Ford's Web site for at least 15 minutes and never did come to that set of pages. Thanks much. It won't be long now and everything I own in the world will be right behind my new F350 - I can hardly wait!. Best regards, |
Sounds great!!!
I am very envious. |
Regards, 1) Duramax 2) Allison Transmission 3) It weighs 1/2 T less than a SD (think gross combined weight here) |
I read that the Duramax is getting 620 ft lb and some HP and the allison is getting the tap shift 6 speed for 06.
