question about the vin
Will the last 6 characters of your vin give you a build date?
This should most likely be asked in a specific vehicle forum and will probably be moved by the moderator, but I'll give you an answer anyway.
Here's a link to the Superduty FAQ's which address VIN decoding. https://www.ford-trucks.com/forums/s...d.php?t=139080 You can only get the model year from the VIN. The last 6 digits are the build sequence number. Build date of the truck is found on the door sticker. Engine build dates (at least for the 6.0 PSD) are a sticker directly on the engine. |
