Fuse Block Diagram 1982 F350
Recently purchased a flatbed F350 Farm Truck to tow a trailer and tractor. The truck has wiring issues for the rear tail lights, turn signals, and trailer brakes. I am looking for a diagram that shows the layout of the fuse panel as some are missing or blown and the panel cover is missing. Thanks.
ST99 |
Did that come out of a Haynes or Chilton?
Neither, 84 Ford Light truck shop manual. It's the same as the cover off of the fusebox in my F250, which has an '82 cab, so, I'd hedge a bet that 80-86 are all the same.
I have a 1980 F-350 4X4 and there must have been some changes in the fuse box and fuse positioning between 80 and 86 or the F-350 has a different layout, because my wiring diagram of the fuse panel is entirely different from the one shown above. If you would like, I can scan the fuse panel diagram and e-mail it to you if the one above is not the same as yours.
My source is the 1980 F-350 factory electrical system manual. |
That seems to be the correct diagram for my F350. I have already located the necessary fuses and they are blown. Now I get to rewire the whole rear of the turck. Thanks for all the info.ST99
Actually, now that I think of it, nearly all the cab wiring in my '80 F100 was different than my 81 or 82, and, the fuse box was laid out differently. I know the diagram above applies for 81-86. I had forgotten about my 80's weird layout.
very helpful thanks
