condensation in motor
Hi every one, I have a Clubwagon ( Quadravan) with a 460. on the breather tube cap and on the dip stick im getting condensation and well it resting the dipstick away. I have never been able to get a proper format for the vaccum lines if any one can help im glad to listen
Someone squeezed a 460 into 61 to 67 Econoline? Oh that van should be a rocking when you step on it.
Have you checked and changed the PCV valve. It should let out moisture when the engine is running so you do not get the condensation in the motor. It does more than crankcase pressure. |
