getting ready to install lift question
i got the procomp 6 inch lift stage 2 looks simple enough to in stall question is directions say acceptable tire and wheel combination 35x12.50 on 15,16,or 17 x8 i got 15x 10 am i gona have clerance issues? it a 92 f150 also got a 3 inch body lift. thanks for any help.
While you should not have a problem with the 35" tires rubbing the fenders, the wheels may contact the radius arms in a tight turn. Depends alot on the backspacing of your 15x10 rims, the less b.s. = the less contact you'll have.
