SI/DO to DI/DO mufflee
my truck has a SI/DO muffler but the muffler i just received is a DI/DO...can this still be installed on my truck?
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question. We are pleased you have chosen the best source for Fords! Enjoy....and JOIN CLUB FTE -SUPPORT THE FORUMS! …..See you on the boards.:-X22 |
Probably the way I'd recommend doing it, is to put a y-pipe on the exhaust before the muffler, that way it splits 1 pipe into 2 before the muffler. Ya gotta use both inlets and both outlets for it to work right. Otherwise, you could use another muffler...
