best stock heads for a 390
I am building up a 390 motor and unfortunately can't afford edel heads but I am wondering if there is a significant difference in stock heads that would fit these fe blocks ? I've heard the 352 heads have bigger exhaust ports. Any info as always is appreciated.
ktownford 68 F250 4x4 390 np435, np205 rev cut dana 44 35" tires w/ 4" lift Should throw a pic of this gal on here! |
i think the stock head of choice around here is the c8ae-h or the d2. the d2 has hardened seats.
If you're looking for more flow, C4AE's are your best bet. You will need to get hardened exhaust valve seats put in though. For an off-road, mud, or work truck, C8's or D2's work great.
What about C6AE?'s? What's the scoop on these?
Well, my book says they're standard 352, 390, 410, and 428 heads. 71.2 - 74.2cc chambers. Standard size ports and valves. You'll need hardened exhaust valve seats though, as with all but the D2 heads. The D2's had hardened seats but the hardening was a surface hardening of the head itself, and not very deep. So if they need more than a valve job or two, they'll need the hardened seats installed also.
Sweet, that's what came stock on my '67. They seem to flow good. I had them redone, they needed new exhaust valves, and I got hardend seats put in and swirl grinded the intake valves.
imo i think getting some c8 or d2 and porting them, good valves, and 3 angle seats are the way to go. Or getting some 428 cj heads if you can find them.
Speaking of heads, I have a 390/2V out of a 65 Galaxie 500 sitting in a 76F100
waiting for me to get off my butt and finish. While I haven't had a chance to look for casting numbers, it's a safe bet that they were designed for leaded gas. My question is this : how long before a steady diet of unleaded gives me problems ? I ask, as I put over 300,000 miles on a 73F100 with a 302/2V before I burnt 3 valves. Many thanks ! |
Strider: The "lead" in gas was used to reduce detonation or pinging, not to add lubrication.
I have run unleaded on my C8-AE heads with non-hardened seats for 150K miles, and I spun a bearing before I burned a valve. |
The lead tends to form a layer on the valve seat. Once formed, you can go for quite a while on unleaded. However, one valve job and it's gone. After that, expect seats to start sinking in about 20,000 miles.
The reason is that the hot exhaust valve tends to micro-weld itself to the seat. This pulls off tiny chunks of the seat, and blows them out the exhaust. The lead prevents this. Remove the lead, and you remove the protection it provides. Hardened seats resist this micro-welding effect. So get the hardened seats. |
or run a lead subsitute but i have c8ae-h and they are great i polished them and did a 3 angle valve job on they and they had 110,000 on the original engine it came out of and only slight marks from not running leaded gas
I think that a good compromise between Edels, and 428CJ iron heads are the C1/C4 heads. With CJ size valves put in them along with hardened seats, and maybe some minor porting and polishing that you would pretty much have at least the equivalent if not better than a 428 CJ head (in terms of flow and cost). They also have a little bit smaller combustion chamber than CJ heads so you wouldn't have to mill them as much depending on your application. The C3 heads would be good to but have a little smaller kidney-bean shaped chamber that is like 67cc and they cost a little more because of that. The C1/C4 heads have the bigger D-shaped chamber that is supposed to be a little smaller than the CJ chambers (I think they average from 72cc to 76cc). Just my .02 cents though.
JC |
