'88 Ranger 2.0L erratic/rich idle 2bbl carb
new motor, new carb.... everything points to the EEC-IV..my Haynes manual says take it to the dealer, does anyone know the procedure Ford uses to set this up...and why does Haynes produce a 400 page shop manual that tells you to "take it to the dealer" just frustrated
I would appreciate your input |
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question. We are pleased you have chosen the best source for Fords! Enjoy FTE :-X22 …..See you on the boards. |
