Ford Truck Enthusiasts Forums
-   1999 - 2003 7.3L Power Stroke Diesel (https://www.ford-trucks.com/forums/forum31/)
-   -   7.3 oil cooler O - ring replacement (https://www.ford-trucks.com/forums/335540-7-3-oil-cooler-o-ring-replacement.html)
Navistar444 01-24-2005 12:50 AM
Hey I was wondering if anyone had changed the o rings on the oil cooler cylinder on a 95 powerstroke. Mine is leaking and is getting worse, was wondering if it can come apart from the rear by pulling the oil filter adapter. I know i gotta drain the coolant, but all data says that I haver to pull the fan/shroud to get at it. Anyone tried this one? Thanks for any help Josh
Navistar444 01-24-2005 07:46 PM
Anybody had this plroblem? only leaking oil onto the ground, no coolant yet.
ltfox 01-24-2005 09:22 PM
I need to do mine also. I found this tread on the TDS very informitive. About half way down there is a post that also show pics.
http://Cat=&Board=ubb42&Number=22154...v=#Post2215473
Navistar444 01-24-2005 11:17 PM
Ok, so if my front mounting adapter is not leaking then I should be able to pullit from the back? anyone got any other tricks for keeping it together to bolt it up?
Navistar444 01-26-2005 10:13 PM
I am hoping i can pull off the back mount, pull the cylinder, then reasemble without removing the front mount. possible?
wycowboy 02-07-2005 02:40 PM
Would oil cooler o-ring failure give one black sludgy coolant??? I 'n not suer wher my oil cooler is and how to tell if it;s shot any help would be much appricateed!!! I need to know how I'm getting so much iol in my coolant. Thnaks to any one J
ltfox 02-07-2005 05:18 PM
The oil cooler is located behind and under the vacuum pump and powersteering pump right to the block. If you look under your truck find your oil filter and right above it and forward of it. Round cylinder looking thing. I don't know if its common for them to leak internaly but its a possibilty.
International Tech 02-07-2005 07:38 PM
I find it easier to remove the entire cooler assembly togther. Put in a vise and remove the front and rear sections. Clean the cooler itself and housings. Install new o-rings with eng assembly lube (helps w/ installing the housings back on). Ive been lucky one time to have both housings go on w/o putting them in a press. Be careful you can break the aluminum housings.
wycowboy 02-07-2005 10:23 PM
thanks!! is that a place I could get coolant mixing w/ oil what about replaceing the whole unit as apose to just the o-rings.? I found the thing today,, but how hard is it to get out? thnaks a gain J
International Tech 02-08-2005 05:30 AM
It is a place that coolant can mix w/ the oil. You can get an entire unit but i think you still have to assemble it.
wycowboy 02-08-2005 09:51 AM
Hey internailonal tech, Thanks for the repy, I need some help pin pointing my problem, I have very thick black coolant. and I ve gotten some folk sayiing Injector o-rings, But i'm not sure. I was going to do new injectors soon any how but I'd like to get this fixed all at onec, if its realy the oil cooler since I'' have to fulsch to coolant sys any how. so If you.v got a minute, Could you check out the post buy me (black sludgy coolant) I would love another opinion... Thnanks Much J
bucky7 01-19-2011 10:22 AM
i have a 2003 7.3 super duty and need to remove and repair oil cooler, what is the best process to remove the cooler from engine compartment for relacing o-rings?
cps 01-19-2011 12:41 PM
Hey ,youse guys are in the wrong forum. I am not sure if the 99 and up info is the same for our your oil coolers.
PaysonPSD 01-19-2011 05:41 PM
A bit of oil cooler info:
https://www.ford-trucks.com/forums/a...0&d=1267124084
O-rings and gaskets available here:Oil Cooler Seal Kit at Dieselorings
https://www.ford-trucks.com/forums/a...8&d=1255988069
Some can push the headers on by hand but I couldn't. I used a bar clamp doing one end at a time. If you have clamps that fit on a 1/2" pipe that would be more suitable. The bar clamp flexed a bit and was just barely up to the task.
https://www.ford-trucks.com/forums/a...6&d=1274423968
F350-6 01-19-2011 06:24 PM
I think we can forgive them since the 7.3 was probably not separated into NBS vs. OBS back in 2005. :rolleyes:
Got to love the search function, but it usually helps if you pay attention to the dates and look for something a little more recent. It improves the chances of a reply.
For a more recent oil cooler thread, with instructions and pictures, read this link. https://www.ford-trucks.com/forums/9...e-of-year.html
