Power Door Lock actuators
Need help with parts for 1993 XLT 150 either the switchs have failed or the actuators are out, nothing happens when I use either the drivers or passengers switchs, no noise nothing happens 1st passenger side went out now both sides out, any help here what to check?? :mad:
Check the fuse block yet? It's kind of a long shot since you haven't noticed anything else acting up. After that I'm inclined to fault the switch
The same circuit in my wife's Taurus is protected by a thermal circuit breaker, it was HOT to the touch. I found a short to ground by "wiggling" the harness pigtails near their respective device. Her problem was under the power seat. Good luck, Mike |
