Ford Truck Enthusiasts Forums
-   1961 - 1966 F-100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum40/)
-   -   where is the blower motor fuse (https://www.ford-trucks.com/forums/329256-where-is-the-blower-motor-fuse.html)
taylor0987 01-09-2005 07:22 PM
In my 64, the blower motor/fan doesn't operate. I tested and know power is not getting to the fan switch. I have the gauges out and see a fuse box on the back of the light switch. Is the fuse for the blower motor in there?
(I have a wiring diagram but it doesn't show the fuse location)
Thank you
barry 01-09-2005 07:34 PM
No, the fuse on the back of the h/lamp sw. is for the lights only. Have you checked the fuse block under the dash? I would think if it's blown, you'd see it. Plull them out one at a time and check them.
Barry
taylor0987 01-09-2005 08:14 PM
Barry, the only fuse block I can find is the one on the switch. Can you give me a more detailed explanation where the other block is?
Thanks
Customcab 01-09-2005 08:40 PM
I'll take a guess and say its on the fire wall under the dash next / under the emergency brake pull arm; should be a black plastic box with about 6 to 8 slots for various fuze combo's.
That's the location on 65's & 66 for sure.
Hope this helps...
C.C.
taylor0987 01-09-2005 10:02 PM
I went out and checked where you said, C.C., and no luck. I am thinking that the fuse box might be gone. The cigarette lighter is running off of an inline fuse -- the same style as the one the aftermarket 8-track radio is running off of. Does anyone else know where it might be on a '64?
Thanks
taylor0987 01-17-2005 03:35 PM
I got my shop manual today. On 64, the heater and radio fuse ARE on the lighting fuse box. There isn't a second fuse block.
It's way too cold for me to go out and mess with it today though!
