P0442 EVAP Control System Leak Detection
(Small LEak)....What the heck is this? and how do I fix it?
Thanks to Google, I found my answer:
What does that mean?This indicates a fuel vapor leak in the EVAP control system. It means a very small leak has been detected. In fact, the leak can be from a hole as small as 0.04" in diameter. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine. SymptomsYou likely won't notice any drivability problems. CausesA code P0442 most likely means one or more of the following has happened: A loose or improperly affixed gas cap A non-conforming gas cap (i.e. not factory/original brand) A small leak/hole in a fuel vapor hose/tube Other small leak in EVAP system Faulty vent o-ring seal Possible SolutionsWith a P0442, the most common repair is to: Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back. Otherwise, replace the gas cap, or Inspect the EVAP system for cuts/holes in tubes/hoses |
p0442??
did you try any of these repairs?... if so did they work. I had just cleared the bank too lean problems and was with no engine light for about 2 weeks, now it is back and by scanning I got this code p0442.... any advice on where i should check?
Originally Posted by rapturez
(Post 9314112)
I don't see any possible way that an intake manifold leak can cause an evaporative emissions failure.... "Lean" codes, definitely - but a P0442, no.
That was what mine was doing and that was we did to fix it.
