Bolts for a Volare front end
I need the 4 bolts and nuts (2 for each side) that secure the upper control arms of the Volare suspension. These are the ones that allow the alignment to be set and hold the conrol arm in place. Does anyone have an extra set to sell or know where I can buy them?
I got mine at the local parts store. I brought in an old one, and matched it up with new grade 8 bolts. Fit like a charm, and they were cheap.
:-X22 55forder |
Thanks for the info but I don't have the old ones to match up. Are the ones you got the correct type or just regular hex head grade 8 bolts?
The ones I got arent "for the application" only, but they are the same bolt, same threading, and the same length. They were reasonably priced as well.
My buddy that is helping me with my front end said that those were going to work just fine, and hes a real by-the-book kinda guy. I trust his opinion 200%. :-X22 55forder |
JW
Dealer should have them. A front end shop can get them. If I didn't have anything to match up to, I would probably do that to make sure I had a stock quality and fit. |
