Flat 8 Millage
i am thinking of puting a flat 8 in my 90 ranger for nostagic? reasons and was wondering what kind of millage would I or should I get with a 5sp and fairly high rearend.
I get 15-16 mpg in my 48 stock setup. With the OD and you might do better.
The Flatmotor is better measured in "Smiles Per Gallon"
My '51 V-8 overdrive used to get 20mpg. After a rebuild to stock specs, it only gets about 15, I guess the motor is tighter.
With my stock set-up, including 239 V8, Heavy Duty 3 speed transmission, and 4.86 rear end, I've done as well as 18 MPG
What a waste of a flathead...
our all stock 53 mercury with the 255 flathead with dual exht gets 20 mpg
