What lube for slip yolk?
What should I use to lube my slip yolk? I'm thinking wheel bearing grease.
Absolutely correct.
Thank you, I will begin the task with confidence knowing I am doing it right instead of guessing.
Here's another possiblity:
https://www.ford-trucks.com/forums/s...d.php?t=266696 In addition, teflon-based greases are also recommended highly by many Ford Techs for lubing slip yokes. |
Sta-Lube makes an extreme-pressure moly grease suitable for slip yoke splines.
Steve |
