Harmonic Balancer Question
Hi all, I hope someone can help me out. I have a 97 Ford ranger 2.3L that i am trying to replace the timing belt. I have removed the harmonic blancer bolt and im trying to get the darn thing off. It looks as if the serpitine pully and the harmonic blancer assy is one piece. The only problem is there are no bolt holes in the pulley to pull the assy off. Can someone please give me some advice on this thanks and have a good day.
Aren't there 4 bolts going thru the serpintine pulley into the balancer??? These hold the
pulley on the cast balancer. You can then use a balancer puller into those holes. |
Hi,The only bolt is the center bolt that holds the whole assy on. Inside the serpitine pully it is tapered. NO other bolt holes to be found inside.
Rrsadiler; I recently had the same problem with my '96 2.3. Several forum users kept advising me that the damper had tapped holes and to use a regular damper puller. Like yours, mine does not have any holes other than the large one in the center. I went to Sears and bought a gear puller. Sears sells several sizes of gear pullers. You will need the large one. I think it handles up to eight inch gears. The large puller was able to grasp the outer edge of the damper. The good part is that it didn't take much pressure from the puller before the damper/pulley popped right off the shaft. The bad part is that you may have to pull the radiator because of the length of the puller bolt.
Good Luck, hope this helps |
I just use two pry bars and wiggle it off.Unless they are really rusted on they come right off.
Thanks fellows, I went down and bought a six inch gear puller and it came right off. Keep them motors running.
Damper pulley
8D Ford has a special puller for these no bolt dampers 150.00 plus tax, I hope this works for me. I sure heck will give it a try thanks Guys I had just about purchased that exspensive bolt and nut looking tool. Thanks again to all
...Welcome moochy1, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
. We are happy you have chosen the best source for Fords! Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS! …..See you on the boards.:-X22 |
