blend door problem
I have 98 explorer and recently the temp control is malfunctioning -- only hot air-- is this the dreaded blend door ? Has anyone experienced this?
thanks |
Check for vaccuum leaks before tearing anything apart.
Steve |
Blend door
Blend door fix shouldn't be dreaded. Pretty simple fix, just takes some patience. My failure was to full heat, and I spent a significant amount of time on it until I found this forum. hard to believe someone had the ingenuity to develop the fix.
