Ford Truck Enthusiasts Forums
-   Explorer, Sport Trac, Mountaineer & Aviator (https://www.ford-trucks.com/forums/forum32/)
-   -   99 Explorer O2 Sensor failed (https://www.ford-trucks.com/forums/291793-99-explorer-o2-sensor-failed.html)
stunod2002 10-06-2004 11:02 AM
Hi all..
I have a 99 ford explorer 4D, 4WD V6.
I have a Check engin light on that is reporting code 171 - O2 Sensor - Bank 1 is reading to lean..
Can someone point me to where this is located on the truck? The Bank one leads me to believe that there are more than one and I would rather not drop the $60 more than I need to :)
Thanks for the help :D
Pig Pen Jr 10-06-2004 02:17 PM
When I replaced the ones on my '99 XLT there were 4. One on the exhaust pipe before the cat and one after the cat on each side. They look like spark-plugs that are screwed into your exhaust system.
stunod2002 10-06-2004 02:31 PM
I just got off hte horn with my local shop.. They told me that Bank 1 is right before the CAT... But I only have 2, not 4
Thanks for the reply.... Appreicate the help
ajguzik 10-08-2004 07:24 AM
# of O2 sensors
I believe that all Explorers thru '99 have 4 sensors. On my '96 with a V6, sensor #1 is located on the passenger side exhaust manifold about halfway between the exhaust header and the converter. Best access is through the wheel well by removing the inner fender skirt. I thought only Rangers with the 2.3L had two sensors?
stunod2002 10-08-2004 07:31 AM
I really have no clue.. I am at this point believing the ford guy, after all he should know :rolleyes:
I will find out for sure tomorrow when I get down underneath it and see it for my self..
Pig Pen Jr 10-08-2004 08:01 AM
He probably has the standard 4.0 and not the 4.0 SOHC. That is the only differance I can see it being.
stunod2002 10-08-2004 08:27 AM
Not sure.. I will have to check
stunod2002 10-09-2004 11:12 AM
I actually have the SOHC 4.0
stunod2002 10-09-2004 01:22 PM
Well There is infact 4 sensors.. I could not find anything that specifically said what Bank #1 was, however the wonderful techs at AutoZone said that it was the driver side.. SoI gave that a shot.. I cleared error code so not its a wait and see..
Hopefully the AutoZone guys know what they are talking about..:rolleyes:
Luckilly that sensor wasn't all that bad so I can change it to the other side if needed.. ;)
'99 black sport 10-09-2004 10:17 PM
I have the ohv standard 4.0, not the sohc.......they all have 4 o2 sensors. banks1 and 2 are before the cats....banks 3 and 4 are after.
