how do you build your gallerie
how do you build your gallerie and why dont they have a article on it for us non computer wizzes i cantbe theonly onewho cantfigure this out?
Should be listed under your User CP login... to the left side of the screen you should be able to add or edit the gallery. You need to fill in everything information wise you can on creating one...
Hey, I've had the same problem EVERYTIME I tried to create my gallery....I finally gave up! After alot of posts in the "User Gallery" and alot of replies to my questions I still cannot figure it out.....and I'm pretty good on the computer....
Good luck! |
Ya I had a problem also...I just remember having to fill in all the blanks or it wouldnt show a album for some reason....
Yeah, it took me awhile to sort it out, too. Just keep working with it, and it'll all fall into place pretty quick. It's kind of like working on a little problem on the truck. Some trial and error, some inspiration, some luck....
Moved to proper forum. Every problem you could possibly have has been discussed here in this forum. It really is very simple unless you try to upload big pictures. You just fill in the blanks and go. Even I can do it! :)
As Balasharky says, I tried numerous times without success; then tried just now and filled in ALL the fields, and it finally worked......
I cant find anywhere tro create a gallery.
Only edit and its hard to edit something Ive yet to create!!!!!! |
Click Edit/Create to create the gallery using a suitable name for it.
Once the gallery is created,you need to create albums to put pics in. Make sure you create the albums in the order you want them in. Upload the pics in the order you want them in as well. Make sure before you upload anything,you read the content guideline's in the thread just above this thread. |
